Hi, I'm newbiee to arm keil.
I need library to use at my arm project, so I try to make library using arm keil.
When I try to build, compile is ok, but ony running 'arm-none-eabi-ar' is failed.
Making source code as .o is ok menas that compiler path is correctly configured, and I checked rwx permission for my arm-none-eabi-ar , and figured out execution permission is ok.
When I execute arm-none-eabi-ar with locally, it is ok. But only when I try to trigger Arm keil, It failed.
Does anyone have clue on this problem ?
I attached my build log
Tool Versions: Toolchain: MDK-ARM Essential: 2 user(s) Version: 5.27.1.0 Toolchain Path: C:\Program Files (x86)\GNU Arm Embedded Toolchain\10 2021.10\bin C Compiler: GCC.exe Assembler: AS.exe Linker/Locator: LD.exe Library Manager: AR.exe Hex Converter: OBJCOPY.exe CPU DLL: Dialog DLL: Target DLL: UL2V8M.DLL V1.5.15.0 Dialog DLL: TCM.DLL V1.36.1.0 Project: A:\ssp\ssp\src\libcbor\uvision\ssp_libcbor.uvprojx Project File Date: 07/26/2023 Output: Rebuild target 'Target 1' compiling callbacks.c... compiling bytestrings.c... compiling allocators.c... compiling arrays.c... compiling floats_ctrls.c... ../src/cbor/floats_ctrls.c: In function 'cbor_float_get_float': ../src/cbor/floats_ctrls.c(59): warning: control reaches end of non-void function [-Wreturn-type] compiling common.c... compiling ints.c... ../src/cbor/ints.c: In function 'cbor_get_int': ../src/cbor/ints.c(52): warning: control reaches end of non-void function [-Wreturn-type] compiling maps.c... compiling serialization.c... ../src/cbor/serialization.c: In function 'cbor_serialize': ../src/cbor/serialization.c(41): warning: control reaches end of non-void function [-Wreturn-type] ../src/cbor/serialization.c: In function 'cbor_serialized_size': ../src/cbor/serialization.c(152): warning: control reaches end of non-void function [-Wreturn-type] ../src/cbor/serialization.c: In function 'cbor_serialize_uint': ../src/cbor/serialization.c(188): warning: control reaches end of non-void function [-Wreturn-type] ../src/cbor/serialization.c: In function 'cbor_serialize_negint': ../src/cbor/serialization.c(204): warning: control reaches end of non-void function [-Wreturn-type] ../src/cbor/serialization.c: In function 'cbor_serialize_float_ctrl': ../src/cbor/serialization.c(368): warning: control reaches end of non-void function [-Wreturn-type] compiling encoding.c... compiling cbor.c... ../src/cbor.c(12): warning: ignoring '#pragma clang diagnostic' [-Wunknown-pragmas] ../src/cbor.c: In function 'cbor_copy': ../src/cbor.c(287): warning: control reaches end of non-void function [-Wreturn-type] ../src/cbor.c: In function '_cbor_copy_float_ctrl': ../src/cbor.c(152): warning: control reaches end of non-void function [-Wreturn-type] ../src/cbor.c: In function '_cbor_copy_int': ../src/cbor.c(137): warning: 'res' may be used uninitialized in this function [-Wmaybe-uninitialized] compiling streaming.c... compiling strings.c... compiling tags.c... compiling loaders.c... compiling memory_utils.c... compiling stack.c... compiling builder_callbacks.c... compiling unicode.c... compiling encoders.c... creating Library... --- Error: failed to execute 'arm-none-eabi-ar' "libssp_libcbor.a" - 1 Error(s), 11 Warning(s). Software Packages used: Package Vendor: ARM www.keil.com/.../ARM.CMSIS.5.5.1.pack ARM.CMSIS.5.5.1 CMSIS (Cortex Microcontroller Software Interface Standard) Collection of Component include folders: .\RTE\_Target_1 C:\Users\mjbean.kim\AppData\Local\Arm\Packs\ARM\CMSIS\5.5.1\Device\ARM\ARMCM35P\Include Collection of Component Files used: Target not created. Build Time Elapsed: 00:00:08
