Keil uVision5 ARM CORTEX M23 Error
Hi there!
I'm new on bare-metal programming and trying to code a basic template (a main that increments the counter var value) for Renesas RA2A1 evaluation board. The reason of doing bare-metal without the smart configurator of Renesas is due to avoid the FSP and BSP that e2studio always uses, in order to have the control of all code parts. The need to have all the control of the code is due to a safety related environment, needed to certify in the future. So when starting a simple project, I use ARM Cortex M23 (ARMCM23) template with the CMSIS Core and Device Startup software components selected. I'm following a Udemy course of Complete ARM Cortex-M Bare-Metal Programming (Israel Gbati), he starts the project as I explained and the add to the source group a main.c file with just the following:
Int main ()
Int counter = 0;
++counter;
Seems a simple code that should compile correctly, but when building always gives the same error:
.\Objects\CoreBox.axf: Error: L6218E: Undefined symbol Image$$ARM_LIB_STACK$$ZI$$Limit (referred from startup_armcm23. o).
Not enough information to list load addresses in the image map.
Searching on the internet and forums as well seems a common error about configuration, but the given solutions don't solve out the problem. Does anyone know what I'm doing wrong?
I attach the project. Thanks in advance!
ARM CORTEX M23.rar
0
