Help with linker error
Hi
I am using an STM32F437 with v6 compiler (armclang).
For various reasons, I am reserving a section in internal flash, in the middle of my application code, like so:
volatile const byte reserve_section[100] __attribute__((section(".ARM.__at_0x0800F000")));
However, when I perform the link, I get the following error:
.\Object\i-onG3MM\Debug\i-onG3MM.axf: Error: L6286E: Relocation #REL:1 in fs_fat.o(.text.fat_unmount) with respect to Veneer$$LitPool. Value(0xffffe458) out of range(0 - 0xff) for (R_ARM_THM_PC8)
I get more similar errors if I reserve a bigger section.  What does this mean exactly, and any suggestions on how to fix ?
TIA
