Hi all,
We are about to start evaluation in the following development environment specified by the module manufacturer.
ST Micro NUCLEO-L073RZKeil μVision V5 ( V5.29 )STM32cubeMX (V 6.0.1 ,STM32Cube MCU Package for STM32L0 1.11.3)
I get an error like below:Could you give me some advice on how to deal with it about error A1023E and error #5?
"""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""Rebuild started: Project: xxx_20230622*** Using Compiler 'V5.06 update 7 (build 960)', folder: 'C:\Keil_v5\ARM\comp v5\Bin'Rebuild target 'xxx_20230622'assembling startup_stm32l073xx.s...startup_stm32l073xx.s: error: A1023E: File "C:/Users/xxx/STM32Cube/Repository/STM32Cube_FW_L0_V1.11.0//Drivers/CMSIS/Device/ST/STM32L0xx/Source/Templates/arm/startup_stm32l073xx.s" could not be opened: No such file or directorycompiling rtc.c......
"no source": Error: #5: cannot open source input file "../Src/system_stm32l0xx.c": No such file or directory../Src/system_stm32l0xx.c: 0 warnings, 1 errorcompiling CXM150x_CTRL_FW_UPDATE.c...
"xxx\xxx.axf" - 2 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:16"""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""""
Best regards,sss jpn
An idea is to compare your project and its settings with the L073RZ CMSIS-RTOS Blinky project, offered by the Pack Installer.
Also, I recommend updating to
- our latest Keil MDK release (by today: V5.38a)
https://developer.arm.com/Tools%20and%20Software/Keil%20MDK
- Arm Compiler 6
https://developer.arm.com/documentation/ka005198/latest/
