Program Size: Code=296716 RO-data=10516 RW-data=3536 ZI-data=125080
At the compilation time, is the RAM data ( RW-data + ZI-data ) is inclusive of the Stack as well?
Hello Arran,
No, the stack (nor heap) is not included in these numbers. You would place these in their own region, named ARM_LIB_STACK, ARM_LIB_HEAP, or a combined ARM_LIB_STACKHEAP region.
You can generate stack info at linktime with --info=stack:https://developer.arm.com/documentation/101754/0620/armlink-Reference/armlink-Command-line-Options/--info-topic--topic-----armlink-
You may also find this application note useful:https://developer.arm.com/documentation/kan316/latest/
See also:
"UVISION DEBUGGER: Enabling the Stack Usage Watermark Feature"
https://developer.arm.com/documentation/ka002825/latest/
and
"UVISION DEBUGGER: Accessing Stack Usage Watermarking Results
https://developer.arm.com/documentation/ka002216/latest
