PRESERVE8 equivalent instruction in ARM Compiler 6
I am trying to migrate my project to ARM compiler 6.19 from an older version (5.xx).
In Compiler 5.xx, I know that the asm instruction "PRESERVE8" is used to specify that the current file preserves the eight-byte alignment of the stack.
This instruction is causing a linker error and I couldn't find any translation in the document "Migrate ARM Compiler 5 to ARM Compiler 6" or any other online forum.
How do I rewrite this instruction compatible with ARM Compiler 6? Is there any documentation available that describes how to resolve this issue?
Any help is much appreciated. Thank you
0
