Does Keil RTX4 and RTX5 support GigaDevice Cortex-M4 micrcontrollers? Specifically, the GD32F427 series
It's not listed in the RTX device list page
Keil RTX Real-Time Operating System
The giga device example code has FreeRTOS example but no RTX examples.
You are referring to a compatibility list for RTX4 and RTX5 which is based on our old device database. RTX5 implements a CMSIS-RTOS v2 API and is compatible with all Cortex-M based MCUs. Please see for more details:
https://developer.arm.com/Tools%20and%20Software/Keil%20MDK/RTX5%20RTOS
https://arm-software.github.io/CMSIS_5/develop/RTOS2/html/pHardwareRequirements.html
You can search for example projects of similar/compatible microcontroller.
Gotcha thanks, is RTX4 also compatible with all Cortex-M based MCUs? Is RTX4 still supported or now its just RTX5?
> … is RTX4 also compatible with all Cortex-M based MCUs?
No. It is compatible with Cortex-M0, M3 and M4 based devices, but not with all ARMv8-M devices, so no Cortex-M23, M33 and M85.
RTX4 is not maintained anymore. It is still part of a CMSIS pack, but we don't make any changes or feature extensions for it.
Thanks!
