I have imported the projects: DISCO-F746NG_AUDIO_demo and DISCO-F746NG_LCD_demo
I get each time this kind of error (for many different library names, each time I restart the build appears another one):
Build startedUsing toolchain ARMC6 profile {'ENV': {'ARMLMD_LICENSE_FILE': '8224@10.100.158.60:8224@10.100.125.150'}, 'PATHS': {'ARMC6_PATH': '/opt/ARMCompiler6.15.13/bin/', 'ARM_PATH': '/opt/armcc5_06_u6/'}, 'common': ['-c', '--gnu', '-O3', '-Otime', '--split_sections', '--apcs=interwork'], 'cxx': ['--cpp', '--no_rtti'], 'COMPILE_C_AS_CPP': False, 'NEW_SCAN_RESOURCES': True}scan /tmp/chroots/ch-1d61af4e-2aca-48fe-a24b-57260762ca26/srcscan /tmp/chroots/ch-1d61af4e-2aca-48fe-a24b-57260762ca26/extras/mbed-os.libLibrary name 'events' is not unique (defined in '/tmp/chroots/ch-1d61af4e-2aca-48fe-a24b-57260762ca26/extras/mbed-os.lib/events/mbed_lib.json' and '/tmp/chroots/ch-1d61af4e-2aca-48fe-a24b-57260762ca26/src/mbed-os/events/mbed_lib.json')Internal error.Build failed
What can I do in order to fix it?
What Tools and which example project do you use? I don't think you are using the Keil MDK Arm. You are probably wrong in this part of the forum.
Where is the right place for the ARM Keil Studio? I have used the mbed platform and I had to migrate to ARM Keil Studio.
I'm having the same problem. The library names changes each time I attempt a build.
