Hello support team,
I am using MDK-ARM v5.38 with ARM compiler 5.06u7 to compile Rensas/Dialog DA14531MOD device.
In my previous computer, every works out of the box.
But once I installed Keil on my new PC with the same toolchain I got the following error, which that the license is not set correctly (See below)
My Keil is licensed as a PRO version
Please advise back on what I am doing wrong here.
Waiting for your kind feedback, many thanks.
Best Regards.
Shai Berman
I recommend installing Arm Compiler 5 by carefully following:
"Can I add Arm Compiler 5 to Keil MDK 5.37 or newer?"
https://developer.arm.com/documentation/ka005073/latest
Do you still face this error afterwards?
