I want to develop program for LPC2148 but Keil 5 is not supporting.
Please guide
I consider that you're using Keil MDK 5.
1. In this case, it is required to possess either a Keil MDK Pro- or a Keil MDK Plus license:
http://www2.keil.com/mdk5/selector
2. The LPC2148 selection then requires to install the MDK Legacy v4 Support:
https://www2.keil.com/mdk5/legacy
3. If you intend to use Arm Compiler 5, carefully follow
"Can I add Arm Compiler 5 to Keil MDK 5.37 or newer?"
https://developer.arm.com/documentation/ka005073/latest
Tried but not solved
In this case, open a Support Ticket and confirm:
- your license key
- the Keil MDK version in use
Also,
- detail the current status
- and refer to this Forum post
Support Ticket: https://www.arm.com/support/contact-support
