Hi
I have the following issue.
When I download my code (C8051 F126 mC) it says all ok below, but it is not functioning properly as I see from the LED when it should enter main loop (crashes somewhere).
When I run debug mode (using USB debug adapter from Silicon Labs) the code loads properly and works fine !
I have other codes that download fine. I don't understand why this will not load properly. The flash tool configuration look the same (screenshots below). Any ideas ?
*** AGDI-Msg: Attempting Connection.*** AGDI-Msg: Connection successful.Flash Erase Done.*** AGDI-Msg: AG_Init code 788*** AGDI-Msg: AG_Init Status: AG_STARTFLASHLOAD.*** AGDI-Msg: Attempting Connection.*** AGDI-Msg: Connection successful.Flash Image Update Complete. Beginning programming...Flash Program Done: 120492 bytes programmed.Checksum:0x9ae8Flash Verify Done: 120492 bytes verified.
Found the solution. It had to do with optimization level of a specific file (had higher optimization).
Code is close to max allowed and maybe there was some problem there but I had no warning.
