When i cofgure PC-Lint,I find it not like as Help。
This is Help Picture。
It is my actual Picture.
Keil-MDK Version:5.38a
Compiler:6.19.
PC-LINT:9.00L
PC operating system: Win11 22H2.
I don't understand the 2nd picture, please explain your problem in more detail.
But, I can access the PC-Lint Help page on my Win-10 installation
-> To what folder do you have installed Keil MDK?
-> Is this a registered or a Lite installation of Keil MDK?
( We've tested successfully calling PC-Lint's Help in a Win11 environment )
It seems that there is something wrong with the scaling of the dialog. You will probably see similar effects in other tabbed dialogs in µVision as well.
We have occasionally seen effects like this in the past when the screen scaling was adjusted to custom values. I have tested this again with a Win11 laptop and selected a scaling factor of 100%, 125%, 150%, and 175%, but this dialog always showed as expected. Did you select a different value?Your screen capture does not look like it was made on a Win11 machine. Did you select a specific Windows Theme, or did you select custom system fonts?
Hello, do you know how to configuration Manager Run Time Environment Keil for STM32F407ZGT6 microcontroller?
I am new to STM and Keil developing, thanks a lot to any answer!
As this is a new topic - for the reason of clarity - please open a new Post at our Forum, thanks
