When #defines are created using the project settings rather than in the source code, the syntax highlighter incorrectly dims sections between #ifdef / #endif blocks in header files.
For example, if I define DEBUG in the project settings and then have this in a header file:
// header.h#ifdef DEBUGvoid do_debug_thing(); // this line dimmed incorrectly#endif
// header.h
#ifdef DEBUG
#endif
Does this make sense? I'm using the latest Keil V5 as of 18th January 2023.
Thanks,Charlie.
On my side it works fine with MDK v5.38a:
If the symbol is defined in the project settings then it works. To see the problem, use the Misc Controls section to include a header file automatically and then define symbols in that header file.
For example, create a file called header.h
#pragma once
#define TESTING
Then, in Misc Controls, add -include "header.h"
Then, in a C source file, try this
#if !defined(TESTING)
int test; // This line will be dimmed when it shouldn't be
still no problem on my side:
I haven't tried in 5.38, can't get free license to work with compiler V5
