including .a static file problem, does not compile
Hey,
I tried including a .a static library file and it fails to compile it
Any ideas on how to properly do it?
Thanks!
  • Hi,
    solved it by changing the File Type for the .a file
    But it still will not compile because of alot of the following errors ..
    .\_build\nrf52832_xxaa.axf: Error: L6242E: Cannot link object kb.o as its attributes are incompatible with the image attributes.
    ... wchart-16 clashes with wchart-32.
    .\_build\nrf52832_xxaa.axf: Error: L6242E: Cannot link object rb.o as its attributes are incompatible with the image attributes.
    .\_build\nrf52832_xxaa.axf: Error: L6242E: Cannot link object boosted_tree_ensemble.o as its attributes are incompatible with the image attributes.
    .\_build\nrf52832_xxaa.axf: Error: L6242E: Cannot link object sorted_copy.o as its attributes are incompatible with the image attributes.
    any Idea?
  • It looks like your library (.a) was compiled using a different setting for wchar. Check the "Short enums/wchar" C/C++ settings for your project.
