Looking for information on .vectors_ram in a scatter file. The call is in the scatter file but nothing appears in the .map file. Where does it originate.
Usually, you have a section specified in assembly startup file for vectors like:
AREA RESET, DATA, READONLY
and then in the linker script you can use something like below to position it:
*.o (RESET, +First)
Producing a result in the map file like below:
__Vectors 0x08000000 Data 4 startup.o(RESET) __Vectors_End 0x08000188 Data 0 startup.o(RESET)
all of this is relevant if you use ARM Compiler 6 (and Linker), for other toolchains you have to see how it is done there.
