Hi all! must your help here.
I working of EFM32G222F128 and use with TIMER0 as PWM.
When I set freq of PWM (on code) = 1kHz -> I got 1kHz
When I set freq of PWM = 500Hz -> I got 500Hz
When I set freq of PWM = 50Hz -> I got ~790Hz (this frequency needed)
When I set freq of PWM = 3Hz -> I got 3kHz
What's going on here?!
The code for freq:
sl_pwm_config_t pwm_servo_config = { .frequency = 50, .polarity = PWM_ACTIVE_HIGH, };
and for TIMER0:
void TIMER0_Init (void) { /* Enable clock for TIMER0 module */ CMU_ClockEnable(cmuClock_TIMER0, true); /* Select TIMER0 parameters */ TIMER_Init_TypeDef timerInit = { .enable = true, .debugRun = true, .prescale = timerPrescale1024, .clkSel = timerClkSelHFPerClk, .fallAction = timerInputActionNone, .riseAction = timerInputActionNone, .mode = timerModeUp, .dmaClrAct = false, .quadModeX4 = false, .oneShot = false, .sync = false, }; /* Enable overflow interrupt */ TIMER_IntEnable(TIMER0, TIMER_IF_OF); /* Enable TIMER0 interrupt vector in NVIC */ NVIC_EnableIRQ(TIMER0_IRQn); /* Set TIMER Top value */ TIMER_TopSet(TIMER0, 1000); /* Configure TIMER */ TIMER_Init(TIMER0, &timerInit);
Thanks,
Gal.
