im using 8051 microntroller send the data one contoller to another controller frame formet but my data is missing and not working
*one controller is transmiting/receiving and another controller is receiving /transmiting
This is my code:
#include<reg51.h>
#define len 6#define identical 0xA5#define START 0x55#define checksum (A,B,C,D)(A+B+C+D+)#define END 0xA2unsigned char RX_data;//unsigned char receivedChar=0;//unsigned char var;unsigned char TX_data[len];//void serial_isr() interrupt 4 //{ // if(RI == 1)// {// receivedChar = SBUF; // Copy the received char// SBUF = receivedChar; // echo the character back// RI = 0; // Clear the Receive interrupt flag// }// else if(TI == 1)// {// TI = 0; // Clear the Transmit interrupt flag// }//}void Transmit_data(char tx_data){ SBUF = tx_data; /* Load char in SBUF register */ while (TI==0); /* Wait until stop bit transmit */ TI = 0; /* Clear TI flag */}unsigned char Rx_char(){ unsigned char Rx_Data; while(RI == 1); Rx_Data = SBUF; SBUF=Rx_Data; RI = 0; return(Rx_Data);}
void main(){ P0=0xff; SCON = 0x50; // Asynchronous mode, 8-bit data and 1-stop bit TMOD = 0x20; // Timer1 in Mode2. TH1 = 0xFD; // Load timer value for 9600 baudrate TR1 = 1; // Turn ON the timer for Baud rate generation ES = 1; // Enable Serial INterrupt EA = 1; // Enable Global Interrupt bit // receivedChar=P0; TX_data[0]=identical; TX_data[1]=START; TX_data[2]=P0; TX_data[3]=END; while(1) { // LEDs = receivedChar; Transmit_data(TX_data[0]); Transmit_data(TX_data[1]); Transmit_data(TX_data[2]); Transmit_data(TX_data[3]); } }
#include<reg51.h>#define LEDs P1#define len 6unsigned char TX_data[len];unsigned char receivedChar=0;//unsigned char RX_data[5];
int i=0,j=0;unsigned char get;
//void serial_isr() interrupt 4 //{ // if(RI == 1)// {// receivedChar = SBUF; // Copy the received char// SBUF = receivedChar; // echo the character back// RI = 0; // Clear the Receive interrupt flag// }// else if(TI == 1)// {// TI = 0; // Clear the Transmit interrupt flag// }//}///void Transmit_data(char tx_data)// {// SBUF = tx_data; /* Load char in SBUF register */// while (TI==0); /* Wait until stop bit transmit */// TI = 0; /* Clear TI flag */// }
un signed char Rx_char(){ unsigned char Rx_Data; while(RI == 0); Rx_Data = SBUF; SBUF=Rx_Data; RI = 0; return (Rx_Data);}
//void Transmit_data(char tx_data)//{// SBUF = tx_data; // /* Load char in SBUF register */// while (TI==0); /* Wait until stop bit transmit */// TI = 0; /* Clear TI flag *///}
void main(){// P1=0x00; P0=0xff; SCON = 0x50; // Asynchronous mode, 8-bit data and 1-stop bit TMOD = 0x20; // Timer1 in Mode2. TH1 = 0xFD; // Load timer value for 9600 baudrate TR1 = 1; // Turn ON the timer for Baud rate generation ES = 1; // Enable Serial INterrupt EA = 1; // Enable Global Interrupt bit// P0=0xff;// receivedChar=P0; // unsigned char get;// get=Rx_char();
while(1) {// get=Rx_char();// TX_data[2]=get;// LEDs=TX_data[2];
unsigned char get;// get=Rx_char();// TX_data[i]=get;// // if(i>=4) i=0; TX_data[i++]=get; if(i==3)
LEDs=TX_data[2];// // // // Transmit_data(receivedChar); }}
