Hello
I want to get startup file of efm32pg22 for support keil , I have download pack of efm32pg22 in Keil5,
I can found many startup files in path : C:\Keil_v5\Packs\SiliconLabs\GeckoPlatform_EFM32PG22_DFP\4.1.1\Device\SiliconLabs\EFM32PG22\Source ,
in this file , I cann't found ARM folder ,and other MCU have three folder(ARM / GCC / IAR ),
so it makes me migrate to IAR , but , I perfer to use KEIL,
so how can I use compile efm32pg22 MCU code with Keil5 , and KEIL give up support efm32pg22 series MCU ?
thank you !
Hi there, I have moved your question to the Keil forum. Many thanks.
Don't understand what's going on. Google suggested me this link https://www.keil.com/dd2/siliconlaboratories/efm32pg22c200f128im32/ But when I clicked, I could see
Link should be: https://www.keil.com/dd2/siliconlabs/efm32pg22c200f128im32/
The full supported device list is at https://www.keil.com/dd2/
the link can not find efm32pg22 startup file for KEIL , because I have search before I raise this question, maybe you can try it ,
thank you
If you possess a valid Keil MDK 5 license key, open a new Support Ticket and detail your request.
https://www.arm.com/support/contact-support
In case you have created already a corresponding project, attach it to this ticket.
Keil Support will then trigger a closer investigation.
