Hi All,
I have a linker scatter file that uses "#!armclang -E --target=arm-arm-none-eabi -mcpu=cortex-m33 -xc" command in the first line to preprocess an included header file.
I've noticed a couple issues that I am not sure the best way to resolve within the KEIL environment.
First is that the header file in not found unless I include the path in the previously mentioned preprocessor command by adding "-I..\..\Linker" to the command.
The second issue is that the header file has references to definitions that are at the project level.
I suspect that both of these issues are related to the fact that the project level settings are not being seen during the linker stage. Is there a way to have the C\C++ include directories and #defines from the project be included during the linker scatter preprocessing?
Thanks for any help!
you can refer to this manual page:
developer.arm.com/.../Preprocessing-a-scatter-file
ChenTang This manual page is good for understanding how to get the preprocessor to run on the scatter file (Which I have no problems doing). The question is "Is there a way to have the KEIL project definitions (Defined in the KEIL project c/c++ settings) to be visible when the preprocessor runs on the scatter file?" I want the defines highlighted in yellow in the picture below to be visible to the preprocessor when processing the scatter file.
After closer reading of the ARM documentation, I have found the following:
https://developer.arm.com/documentation/101754/0618/armlink-Reference/armlink-Command-line-Options/--predefine--string-
This article shows how to perform a predefine in the linker settings and provides examples. For the other part of my question about include directories, I found no solution and so I just used the relative address when #including my file.
UPDATE:I have found that the --predefine can be used for both definitions and include directories
Example Define:
The following examples can be placed in the "Misc Controls" of the linker settings.
This example adds a relative include directory for ../../mydirectory to the include list for the linker:--predefine="-I../../mydirectory"
This example adds a definition for "MYDEFINITION" to the defines for the linker:--predefine="-DMYDEFINITION"
Hope this helps
Thank you coming back and sharing this with the community, much appreciated.
