Confused by some problem,Looking into 2 Case study in ESP serires and WizFi360's CMSIS_DRIVER WIFI Driver (WiFi_WizFi360.c and WiFi_ESPxxxx.c)
1st is at AT_Notify(): updating link_id and SOCKET_STATE_CONNECTED by response for <link_id>,CONNECT2nd is that 1st affect ARM_WIFI_SocketAccept()'s data updating.
Conditions:
Case 1: One Client Connected 0,CONNECT --->(discription: <link_id>,CONNECT)AT+CIPSTATUSSTATUS:5+CIPSTATUS:0,"TCP","192.168.36.2",58428,6000,1has not a problme
Case 2: 2nd Client Connected1,CONNECTAT+CIPSTATUSSTATUS:5+CIPSTATUS:0,"TCP","192.168.36.2",58428,6000,1\r\n+CIPSTATUS:1,"TCP","192.168.36.3",55362,6000,1\r\nhas some problem
Details: 1. When 1st Client CONNECTs Server, AT_Notify() under 292 line code is not a problem.But when 2nd Client CONNECTs Server in case that 1st Client is CONNECTED state<refer to 292 line>if (Socket[n].state == SOCKET_STATE_SERVER) { Socket[n].conn_id = conn.link_id; Socket[n].state = SOCKET_STATE_CONNECTED;}
1st client state can be updated to SOCKET_STATE_CONNECTED and Socket[n].conn_id = conn.link_id;but 2nd client state can not be update to SOCKET_STATE_CONNECTED and Socket[n].conn_id = conn.link_id;
2. Socket's backlog is only updated under 2580 line, when ARM_WIFI_SocketAccept() is called.and because of ARM_WIFI_SocketAccept()'s 2554 line: if (conn.link_id == Socket[n].conn_id) conditions,
the data below lines can not be updated. /* Copy remote ip */ memcpy (Socket[n].r_ip, conn.remote_ip, 4); /* Set remote port */ Socket[n].r_port = conn.remote_port; /* Set local port */ Socket[n].l_port = conn.local_port;
3. To use static int32_t ARM_WIFI_SocketAccept (int32_t socket, uint8_t *ip, uint32_t *ip_len, uint16_t *port) Assuming that Server application use max. 4 connection, does Server application have alway to iterate and check 4 socket, to update Socekt's data and stateexample: for (i=1 ; i<5; i++) //because 0 is server ARM_WIFI_SocketAccept (i, , , ) This question's reason is ARM_WIFI_SocketAccept(){
2551 line: sock = &Socket[socket];2534 line: n = sock->backlog;}"n" is dependent on ARM_WIFI_SocketAccept()'s input argument socket and backlog is updated 2580 lin
4. Can you explain or illustrate how to use "backlog"
Refer to your own code below----------------------------------------------------------------------
AT_Notify(){
292 line start:
else { /* Check server sockets and put connection on the backlog */ for (n = 0U; n < WIFI_SOCKET_NUM; n++) { if (Socket[n].state == SOCKET_STATE_SERVER) { /* Set pointer to server socket */ sock = &Socket[n]; /* Find available backlog socket */ do { n = Socket[n].backlog;
if (Socket[n].state == SOCKET_STATE_LISTEN) { /* Set connection id and change state */ Socket[n].conn_id = conn.link_id; Socket[n].state = SOCKET_STATE_CONNECTED; break; } } while (Socket[n].backlog != sock->backlog); break; } }
if (n != WIFI_SOCKET_NUM) { /* Set event */ osEventFlagsSet (pCtrl->evflags_id, WIFI_WAIT_CONN_ACCEPT); } }
324 line end:
static int32_t ARM_WIFI_SocketAccept(){
2440 line start:
ex = AT_Cmd_GetStatus (AT_CMODE_EXEC);
if (ex == 0) { /* Wait until response arrives */ ex = WiFi_Wait (WIFI_WAIT_RESP_GENERIC, WIFI_RESP_TIMEOUT);
if (ex == 0) { /* Check response */ do { /* Response arrived */ ex = AT_Resp_GetStatus (&conn); if (ex >= 0) { /* Check if structure contains information relevant for current link id */ if (conn.link_id == Socket[n].conn_id) { /* Copy remote ip */ memcpy (Socket[n].r_ip, conn.remote_ip, 4); /* Set remote port */ Socket[n].r_port = conn.remote_port; /* Set local port */ Socket[n].l_port = conn.local_port; } } } while (ex > 0); } } 2566 line end:
2580 line start:
/* Return socket number */ rval = n;
/* Update backlog, put current socket to the end of list */ while (Socket[n].backlog != sock->backlog) { n = Socket[n].backlog; } Socket[n].backlog = (uint8_t)rval; Socket[rval].backlog = sock->backlog; 2588 line end:
2622 line: return (rval);}
