Arm compiler 6 error when redefining __FILE
Hi, I want to redirect printf output to a serial port. A method for this is described here:
Libraries and Floating Point Support Guide: Redefining low-level library functions to enable direct use of high-level library functions in the C library (keil.com)
However, the code described there fails to compile with Arm compiler 6.16 (it compiles fine with GCC):
Fullscreen
1
2
3
4
5
6
7
8
9
#include <stdio.h>
struct __FILE
int handle;
/* FILE is typedef’d in stdio.h. */
FILE __stdout;
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
The error is:
Fullscreen
1
2
3
4
5
6
7
error: redefinition of '__FILE'
struct __FILE
C:\Program Files\Arm\Development Studio 2021.1\sw\ARMCompiler6.16\bin\..\include\stdio.h:119:8: note: previous definition is here
struct __FILE {
1 error generated.
How can I fix this please?
0
