I am trying to write code for toggling a pin(Pin 15) of a port (PORTC) using timers(specifically TIM2). I have to use the prescale registers to divide the clock frequency such that I obtain the required delay for toggling the pin.So I wrote some code after 3 hrs of going through Reference Manual of the STM32F103RB. I checked what is wrong with my program and noticed that the Counter register is not updating even though in enabled the counter. Could anyone tell where I am going wrong? I have attached my code for reference.
#include "stm32f10x.h"
void Q2() { int step = 0; RCC->APB2ENR |= (1<<4); //To enable the PORTC RCC->APB1ENR |= (1<<0); // Enable Timer 2 GPIOC->CRH &= (0<<30); // setting CNF GPIOC->CRH |= (1<<28); // Setting mode to get general purpose Output push pull TIM2->PSC = 0xD2F0; // Prescalar value set such that the 0.5ms is over till overflow TIM2->CR1 |= 1<<7; // Auto reload preload enable is buffered TIM2->ARR = 0x0000; // Auto reload value is 0 TIM2->CR1 |= 1<<0; //Counter enabled
while (1) { TIM2->PSC = 0xD2F0; // Prescalar value set such that the 0.5ms is over till overflow TIM2->CR1 |= 1<<7; // Auto reload preload enable is buffered TIM2->ARR = 0x0000; // Auto reload value is 0 TIM2->CR1 |= 1<<0; //Counter enabled TIM2->SR &= 0<<0; while(step!=2) { if((TIM2->SR && 0x0001) == 0x0001) {
step++; } } step = 0; GPIOC->BSRR |= (1<<15); // set pin 15 of port C TIM2->PSC = 0xD2F0; // Prescalar value set such that the 0.5ms is over till overflow TIM2->CR1 |= 1<<7; // Auto reload preload enable is buffered TIM2->ARR = 0x0000; // Auto reload value is 0 TIM2->CR1 |= 1<<0; //Counter enabled TIM2->SR &= 0<<0; while(step!=2) { if((TIM2->SR && 0x0001) == 0x0001) {
step++; } } step = 0; GPIOC->BSRR |= (1<<31); // reset pin 15 of Port C } }int main (){ SystemInit (); Q2();}
Thank you
