Actually on my product I'm using a NAND flash memory with NO hardware ECC. I use the KEIL software ECC 1-bit on this product.
The memory actually used is an end of life component witch we will replace by another similar BUT the new one has hardware ECC built in. For simplicity reasons I don't want to change the software on my product to disable the software ECC provided by KEIL.
Is there any side effect of using the KEIL software ECC 1bit with a NAND flash with hardware ECC ?
Thank you for your time!
