ADC
Hello Guys, I am try to get the STM32F446RE to read analog signals from a potentiometer and I just cant seem to get it right please help me out, can I please get an example code that works cause even uploading the code I have written just isn't working right now.
  • Here is my attempt to initialize it
    //set clock to 14MHz prscaler
    ADC->CCR |= ADC_CCR_ADCPRE_0;
    ADC->CCR |= ADC_CCR_ADCPRE_1;
    ADC->CCR |= ADC_CCR_TSVREFE;
    //RCC clock for ADC and for alternate function
    RCC->APB2ENR |= RCC_APB2ENR_ADC1EN;
    //Enable GPIO port
    CLOCK_INIT_PORTA();
    //configure input push pull
    //setting up the input
    //setting up the mode
    GPIOA->MODER |= (GPIO_MODER_MODE2_1);
    GPIOA->MODER |= (GPIO_MODER_MODE2_0);//11 input output
    //setting up the PUPDR
    //since we have pulled down push pull alternate function
    GPIOA->PUPDR &=~(GPIO_PUPDR_PUPD2_0);
    GPIOA->PUPDR &=~(GPIO_PUPDR_PUPD2_1);//analog value
    //Enable end of conversion interrupt
    ADC1->CR1 |= ADC_CR1_EOCIE;
    //ADC Resolution 8 bit
    ADC1->CR1 &=~ ADC_CR1_RES_0;
    ADC1->CR1 |= ADC_CR1_RES_1;
    //Set sampling rate choose maximum for the highst precision
    ADC1->SMPR2 |= ADC_SMPR2_SMP2_0;
    ADC1->SMPR2 |= ADC_SMPR2_SMP2_1;
    ADC1->SMPR2 |= ADC_SMPR2_SMP2_2;
    //set channels in sequence reg
    ADC1->SQR3 |= ADC_SQR3_SQ1_1;
    //Enable ADC that is ADON
    //Enable continuous mode
    ADC1->CR2 |= (ADC_CR2_ADON)|(ADC_CR2_CONT);
    //delai for 2ms
    wait_For_t(20);
    //turn on ADC adon for the second time
    //delay 2 ms
    ADC1->CR2 |= ADC_CR2_ADON;
    wait_For_t(20);
    //Run clibration
    //delay to allow the finish
    wait_For_t(2);
  • Hello, I have moved your question to the Keil forum, however you are more likely to get a response from a device specific query like this from the STM32 specific forum below (ST website):
    https://community.st.com/s/topic/0TO0X000000BSqSWAW/stm32-mcus
  • Hello sing did you find the solution because i am also stuck at the same point. Tried so many methods but not found the right solution, i am using the ABOV Microcontroller where as you used stm one. So please let me know if you found the solution for this waiting
    Waiting for your reply!!!
  • An idea is to compare your application with example projects offered by the Pack Installer of Keil MDK:
