My setup: Fresh install on new computer of uVision 5.36 trial version. Windows 10 LTSC.
Problem: uVision forgets my layout every time I restart the application. I've created a new project and customize the tiles position and sizes (build output, search, top bar, etc..) then "save all" and close. When restart the app all tiles are rearranged to it's original possition... I've tried all "compatibility" setups for the app (windows 8, 7, administration rights...) and the problem persist.
I found that if I overwrite the .uvguix file with another generated in a computer where Keil works ok the program is started without problems and layout is like I wanted, but, after restart Keil the file is overwritten and layout restored to defaults.
MDK uVision GUI layout has nothing to do with *.uvprojx file. The GUI layout info is stored in the *.uvguix files
Sorry I wanted to say .uvguix, in fact is "uvguix.Alex"
Related:
"UVISION: Reset View To Customer Defaults"
https://developer.arm.com/documentation/ka004091/latest
"UVISION: Recover From Corrupted Screen Layout"
https://developer.arm.com/documentation/ka002920/latest
Hi, finally I've uninstalled it and then installed an older version that works ok and when reinstall the new one all is working.. I don't know why because I tried to reinstall it many times and a lot of other experiments... Anyway thanks for your answer.
