I am at my wits' end with Keil's debugger. I am much more familiar with plain gdb or the Eclipse standalone debugger. Is it possible to use GDB to connect to a binary running on my dev board using the Segger GDB server, when the binary was compiled in Keil with the ARM C Compiler v5?
I have tried it, and I can set up the GDB Server, and then I use the Eclipse debugger to connect to localhost:2331.
My setup for Eclipse is:
Binary: /path/to/file.bin
Build Log Path: none
Host Name: localhost
Port Number: 2331
Attach: Ticked
When I click on Pause, the programme clearly stops, because it otherwise blinks an LED, and this stop blinking. However, if I open the sources, I am unable to set breakpoints or step through the code.
https://www.segger.com/support/technical-support/
