Hello! Sorry, maybe thats not in address, but I could find the similar decision anywhere I have got keil uvision V5.33.0.0(toolchain MDK-Lite) I integrated offline (cause online doenst connet to server) pack ARM.CMSIS-FreeRTOS.10.4.3 But after that I cant see it in RTE and keil cant add it I documented the problem in pic here
https://dropmefiles.com/Mn0hK
Please help,who knows
After downloading and installing the ARM::CMSIS-FreeRTOS v10.4.3 pack, you can find and open the following documentation located in your pack installation folder, such as file:///C:/Keil_pack/ARM/PACK/ARM/CMSIS-FreeRTOS/10.3.1/CMSIS/Documentation/General/html/index.html to see how to integrate FreeRTOS in your MDK project.
Alternatively you can follow the readme.txt file in your FreeRTOS pack installation folder to start a demo example project to see how FreeRTOS is integrated in those demo projects.
Thank you for your answer
Ill try to read it,but I have another problem with packs
When I try to open project or when I install pack by import I have got the following error:
https://dropmefiles.com/afIPc
Can it be the reason too ?
I unsuccessfully tried to fix it by the following recomendatioin:
developer.arm.com/.../latest
