I'm trying to write the timer interrupt code I wrote in C (pa3 pin blinks at 10 ms intervals) with arm assembly language, but it doesn't work.I don't know exactly how to do the timer interrupt in assembly language.I tried to write my own code by looking at the disassembly feature from keil uvision. So where am I doing wrong? (I'm using stm32f103c8 and c code works properly)
C code=
#include "stm32f10x.h" void TIM2_IRQHandler() { TIM2->SR =0x00; GPIOA->ODR ^=0x0008;//toggle pa3 } int main(void) { RCC->APB2ENR = 0x04; /// port a GPIOA->CRL = 0x00003000; __disable_irq(); RCC->APB1ENR =0x1;// timer2 TIM2->ARR = 0xffff; TIM2->PSC = 0x36; // 10hz TIM2->DIER = 0x1;// (OVERFLOW) TIM2->CR1 = 0x1; // TIMx_CR1.CEN NVIC_EnableIRQ(TIM2_IRQn); __enable_irq(); while(1) { } }
Assembly code=
EXPORT Program GPIOA_IDR EQU 0x40010808 GPIOA_CRL EQU 0x40010800 GPIOB_IDR EQU 0x40010C08 GPIOA_ODR EQU 0x4001080C RCC_APB2ENR EQU 0x40021000 RCC_APB1ENR EQU 0x40021000 TIM2_ARR EQU 0x4000002C TIM2_PSC EQU 0x40000028 TIM2_DIER EQU 0x4000000C TIM2_CR1 EQU 0x40000000 TIM2_SR EQU 0x40000010 AREA start, CODE, READONLY timer_ MOVS r0,#0x00 ; TIM2->SR =0x00;//interrupt flag active MOV r1,#0x40000000 ; GPIOA->ODR ^=0x0008;//toggle pa3 STRH r0,[r1,#0x10] LDR r0,=GPIOA_ODR LDR r0,[r0,#0x00] EOR r0,r0,#0x08 LDR r1,=GPIOA_ODR STR r0,[r1,#0x00] ADDS R7,R7,#1 ;counter for debugging BX LR Program MOVS r0,#0x04 LDR r1,=RCC_APB2ENR STR r0,[r1,#0x18] ; pa3 out MOV r0,#0x3000 LDR r1,=GPIOA_CRL STR r0,[r1,#0x00] ADDS R11,R11,#1 CPSID I MOVS r0,#0x01 LDR r1,=RCC_APB1ENR STR r0,[r1,#0x1C] ; TIM2->ARR = 0xffff; MOVW r0,#0xFFFF LSLS r1,r1,#18 STRH r0,[r1,#0x2C] ; TIM2->PSC = 54; MOVS r0,#0x36 STRH r0,[r1,#0x28] ; TIM2->DIER = 0x1; MOVS r0,#0x01 STRH r0,[r1,#0x0C] ; TIM2->CR1 = 0x1; STRH r0,[r1,#0x00] MOVS r0,#0x1C BL timer_ CMP r0,#0x00 BLT interrupt ; NOP NOP ; NVIC_EnableIRQ(TIM2_IRQn) AND r2,r0,#0x1F MOVS r1,#0x01 LSLS r1,r1,r2 LSRS r2,r0,#5 LSLS r2,r2,#2 ADD r2,r2,#0xE000E000 STR r1,[r2,#0x100] ADDS R8,R8,#1 ;counter for debugging NOP interrupt NOP ADDS R5,R5,#1 ;counter for debugging MOVS R6,#0x3 ;control CPSIE I NOP while B while ALIGN END
I checked the tim2_cnt value in debug mode, it works fine, but when I look at tim2 from nvic, it is not enabled, it is in pending mode
