I am trying to create ADC using STM32F103C8. Software i am using are:
a. STM32CubeMX
b. Keil Vision -- V5
c. Hercules to Monitor the Serial Output
Clock Setting of STM is
Code :-
while (1) { /* USER CODE END WHILE */ HAL_ADC_Start(&hadc1); HAL_ADC_PollForConversion(&hadc1,300); raw = HAL_ADC_GetValue(&hadc1); float vin = (double)raw*(3.3/4096); sprintf(msg1,"Vol = %.2f , HEX Value = %.4x \r\n",vin, raw); HAL_UART_Transmit(&huart1,(uint8_t*)msg1,sizeof(msg1),300); HAL_Delay(1000); /* USER CODE BEGIN 3 */ }
i am getting a constant DC Output of around 1.69 Volt, when input volt at ADC is Zero (Screen Shot attached). After supplying any Voltage value between 0 - 3.3 Volt, output is varying contentiously between 0 to 3.3 Volt.
I have checked the input reference volt, it is 3.3 Volt. Can you suggest me how to resolve this issue. have printed a HEX value of output of function HAL_ADC_GetValue(&hadc1).
