$NOMOD51 $INCLUDE (C:\C51ASM\INC\AT89LP214.inc) USING 00 ORG 0x00 ORG 0x003 ACALL CUADRADA1 ORG 0x013 ACALL CUADRADA0 MOV IE,#10000101B // IE (EA+TMR0+) || EA + EX0 = EN MOV TCON,#00000000B // TCON - START/STOP TMRs || FLANCO BORRA AUTO MOV TMOD,#00000000B // TMOD | (13 bits) MOV CLKREG,#11110001B // CLKREG | TPS / CDV || COE = IN CUADRADA0: SETB P1.6 ACALL TIEMPO1 CLR P1.6 ACALL TIEMPO1 IRQ0: JNB IE0,IRQ0 // Captura IRQ (P3.3) DJNZ 0FFH,CUADRADA0 CUADRADA1: SETB P1.4 ACALL TIEMPO1 CLR P1.4 ACALL TIEMPO1 IRQ1: JNB IE1,IRQ1 // Captura IRQ (P3.3) DJNZ 0FFH,CUADRADA1 RETI TIEMPO1: MOV TL0,#000H MOV TH0,TL0 SETB TR0 REARME1: JNB TF0,REARME1 // Rearma FLAG TMR_0 CLR TF0 CLR TR0 RET END
Hello, I am working in assembler with the AT89LP214 to make some electronic circuits with alternating current and I see some deficiencies in the compiler, because the 2 external interrupts do not work simultaneously? here I show a simple program with the dops interrupts. Has anyone encountered this problem?
What makes you think these are deficiencies in the compiler?
Juanje said:Has anyone encountered this problem?
What problem, exactly?
Hello, Because it ignores the ACSR register configuration instructions, it works to the comparator in minimum performance and detects step x 0, of a frequency, but it does not allow me to configure the trigger for skinny, for example.
Juanje said:it ignores the ACSR register configuration instructions
You mean this:
https://community.arm.com/developer/tools-software/tools/f/keil-forum/49383/the-at89lp214-register-acsr-is-deactived-i-now-reason
See the reply there.
It is highly unlikely that the assembler is at fault: www.catb.org/.../smart-questions.html
