Greetings!
Keil uVision 5, ARM Compiler 6.12, -Os balanced, Cortex-M3. Just as an example
GPIOC->OR = (GPIOC->OR & ~0xFF) | 0x12; while(1) { u32 i = 100000; ... }
MOVS r1, #0x12 LDR r0, [r12, #0x00] BFI r0, r1, #0, #8 MOVW r1, #0x86A0 STR r0, [r12, #0x00] MOVT r1, #0x01
As you can see, there was a reordering of instructions. It is quite legal, I understand that perfectly.But how do you make the compiler not do this here? I want nothing superfluous to be wedged into the GPIOC->OR change
MOVS r1, #0x12 LDR r0, [r12, #0x00] BFI r0, r1, #0, #8 STR r0, [r12, #0x00] MOVW r1, #0x86A0 MOVT r1, #0x01
What optimizer barrier should I use and how?
Why would you want that? The compiler reorders the instructions to better fit the dual-issue pipeline (when two instructions can be executed simultaneously in the same clock cycle). So no time penalty is expected, just a performance increase. For a dual-issue pipeline, the first solution is better than yours as it saves one clock cycle.
Where are the two pipelines on the Cortex-M3?The question was not why I needed this, but whether the compiler tools could influence it.
You're right, I'm sorry, I missed that. You will probably need to implement this piece of code in inline assembly. I am not aware of any compiler directive that prevents the instructions from being reordered.
So I don't know, but I thought, after all, maybe there are such directives... Thank you!
There are barrier instructions available, see the document on the link below:
developer.arm.com/.../
Barriers DMB/DSB/ISB are not applicable here and are used for a completely different purpose.
Perhaps a compile-time barrier?
On gcc:
asm volatile("" ::: "memory");
There has to be a similar construct available with the tools you are using.
Edit: Since we want "nothing superfluous" to be wedged, even the compiler barrier may not work in all cases. There's still a chance that an instruction that isn't a memory access can be wedged in-between. As mentioned elsewhere, writing one's own assembly is a solution.
