Hi all,
I faced with a bit problem is that the C166LIB, C51LIB, and C251LIB environment variables does nothing.
e.g. the documentation say that the C166LIB variable specifies a search path to the libraries to link them:
* https://www.keil.com/support/man/docs/c166/c166_cm_envvars.htm
In my case I have the project with the object files in the following tree:
so, as you can see, the my static libraries locates in the c:\Keil_v5\c166\Examples\foo\libs directory,
and I want to specify a path to this directory for linker search:
and then I run the linker:
but the linker fails:
*** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: LIB-B.LIBit can't find the libraries.Why this happens? How to specify a paths to search the libraries?
