I am working on STM32H753 microcontroller. I want to receive string using UART interrupt and send the same string back on UART. The IDE is keil uvision 5. The problem I am facing is that when I first program the MCU UART is working fine and I am receiving back the string but after completely switching off the supply and restarting it UART is not working properly and I am not receiving the data I sent. I generated my code using stm32cube
int main(void) { device_init(); HAL_Delay(100); HAL_UART_Receive_IT(&huart1,recbuf,80); /* USER CODE BEGIN WHILE */ while (1) { if(rec_data == 1) { rec_data = 0; //Clean and Invalidate data cache //SCB_CleanInvalidateDCache(); HAL_UART_Transmit_IT(&huart1,recbuf,80); } } /* USER CODE END 3 */ }
#include "usart.h" #include "gpio.h" #include "config.h" #include <string.h> #include "timer.h" uint8_t recbuf[100],trnsbuf[100]; unsigned char rec_data; /* USER CODE BEGIN 0 */ /* USER CODE END 0 */ UART_HandleTypeDef huart1; /* USART1 init function */ void MX_USART1_UART_Init(void) { huart1.Instance = USART1; huart1.Init.BaudRate = 19200; huart1.Init.WordLength = UART_WORDLENGTH_8B; huart1.Init.StopBits = UART_STOPBITS_1; huart1.Init.Parity = UART_PARITY_NONE; huart1.Init.Mode = UART_MODE_TX_RX; huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE; huart1.Init.OverSampling = UART_OVERSAMPLING_16; huart1.Init.OneBitSampling = UART_ONE_BIT_SAMPLE_DISABLE; huart1.Init.Prescaler = UART_PRESCALER_DIV4;//UART_PRESCALER_DIV256;//UART_PRESCALER_DIV1; huart1.Init.FIFOMode = UART_FIFOMODE_DISABLE; huart1.Init.TXFIFOThreshold = UART_TXFIFO_THRESHOLD_1_8; huart1.Init.RXFIFOThreshold = UART_RXFIFO_THRESHOLD_1_8; // huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_NO_INIT; huart1.AdvancedInit.AdvFeatureInit = UART_ADVFEATURE_RXOVERRUNDISABLE_INIT|UART_ADVFEATURE_DMADISABLEONERROR_INIT; huart1.AdvancedInit.OverrunDisable = UART_ADVFEATURE_OVERRUN_DISABLE; huart1.AdvancedInit.DMADisableonRxError = UART_ADVFEATURE_DMA_DISABLEONRXERROR; rec_data = 0; if (HAL_UART_Init(&huart1) != HAL_OK) { Error_Handler(); } // HAL_UART_Receive_IT(&huart1,recbuf,80); } void HAL_UART_MspInit(UART_HandleTypeDef* uartHandle) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(uartHandle->Instance==USART1) { /* USER CODE BEGIN USART1_MspInit 0 */ /* USER CODE END USART1_MspInit 0 */ /* USART1 clock enable */ __HAL_RCC_USART1_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); /**USART1 GPIO Configuration PA9 ------> USART1_TX PA10 ------> USART1_RX */ GPIO_InitStruct.Pin = GPIO_PIN_9|GPIO_PIN_10; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP;//GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;//GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF7_USART1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); memset(recbuf,0,sizeof(recbuf)); /* USART1 interrupt Init */ HAL_NVIC_SetPriority(USART1_IRQn, 0, 0);//0 HAL_NVIC_EnableIRQ(USART1_IRQn); /* USER CODE BEGIN USART1_MspInit 1 */ /* USER CODE END USART1_MspInit 1 */ } } void HAL_UART_MspDeInit(UART_HandleTypeDef* uartHandle) { if(uartHandle->Instance==USART1) { /* USER CODE BEGIN USART1_MspDeInit 0 */ /* USER CODE END USART1_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_USART1_CLK_DISABLE(); /**USART1 GPIO Configuration PA9 ------> USART1_TX PA10 ------> USART1_RX */ HAL_GPIO_DeInit(GPIOA, GPIO_PIN_9|GPIO_PIN_10); /* USART1 interrupt Deinit */ HAL_NVIC_DisableIRQ(USART1_IRQn); /* USER CODE BEGIN USART1_MspDeInit 1 */ /* USER CODE END USART1_MspDeInit 1 */ } } void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) { rec_data=1; } // Transmit buffer complete call routine void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart) { transmit_running = 0; HAL_UART_Receive_IT(&huart1,recbuf,100); }
/** * @brief Receive an amount of data in interrupt mode. * @note Function is called under interruption only, once * interruptions have been enabled by HAL_UART_Receive_IT() * @param huart: UART handle. * @retval HAL status */ static HAL_StatusTypeDef UART_Receive_IT(UART_HandleTypeDef *huart) { uint16_t* tmp; uint16_t uhMask = huart->Mask; uint16_t uhdata; /* Check that a Rx process is ongoing */ if(huart->RxState == HAL_UART_STATE_BUSY_RX) { //SCB_DisableICache(); // Disable Instruction-cache at beginning of function in case of success! AKASH EDIT uhdata = (uint16_t) READ_REG(huart->Instance->RDR); if ((huart->Init.WordLength == UART_WORDLENGTH_9B) && (huart->Init.Parity == UART_PARITY_NONE)) { tmp = (uint16_t*) huart->pRxBuffPtr ; *tmp = (uint16_t)(uhdata & uhMask); huart->pRxBuffPtr +=2; } else { *huart->pRxBuffPtr++ = (uint8_t)(uhdata & (uint8_t)uhMask); if(uhdata == '\0') huart->RxXferCount = 1; } if(--huart->RxXferCount == 0U) { //HAL_GPIO_TogglePin(GPIOE, GPIO_PIN_9); /* Disable the UART Parity Error Interrupt and RXNE interrupt*/ CLEAR_BIT(huart->Instance->CR1, (USART_CR1_RXNEIE | USART_CR1_PEIE)); /* Disable the UART Error Interrupt: (Frame error, noise error, overrun error) */ CLEAR_BIT(huart->Instance->CR3, USART_CR3_EIE); /* Rx process is completed, restore huart->RxState to Ready */ huart->RxState = HAL_UART_STATE_READY; HAL_UART_RxCpltCallback(huart); //SCB_EnableICache(); // Disable Instruction-cache at beginning of function in case of success! AKASH EDIT return HAL_OK; } return HAL_OK; } else { /* Clear RXNE interrupt flag */ __HAL_UART_SEND_REQ(huart, UART_RXDATA_FLUSH_REQUEST); return HAL_BUSY; } }
/** * @brief Send an amount of data in interrupt mode. * @note Function is called under interruption only, once * interruptions have been enabled by HAL_UART_Transmit_IT(). * @param huart: UART handle. * @retval HAL status */ static HAL_StatusTypeDef UART_Transmit_IT(UART_HandleTypeDef *huart) { uint16_t* tmp; uint16_t uhdata; /* Check that a Tx process is ongoing */ if (huart->gState == HAL_UART_STATE_BUSY_TX) { if(huart->TxXferCount == 0U) { /* Disable the TX FIFO threshold interrupt (if FIFO mode is enabled) or Transmit Data Register Empty interrupt (if FIFO mode is Disabled). */ if (READ_BIT(huart->Instance->CR1, USART_CR1_FIFOEN) != RESET) { CLEAR_BIT(huart->Instance->CR3, USART_CR3_TXFTIE); } else { CLEAR_BIT(huart->Instance->CR1, USART_CR1_TXEIE); } /* Enable the UART Transmit Complete Interrupt */ SET_BIT(huart->Instance->CR1, USART_CR1_TCIE); return HAL_OK; } else { if ((huart->Init.WordLength == UART_WORDLENGTH_9B) && (huart->Init.Parity == UART_PARITY_NONE)) { tmp = (uint16_t*) huart->pTxBuffPtr; huart->Instance->TDR = (*tmp & (uint16_t)0x01FFU); huart->pTxBuffPtr += 2U; } else { uhdata = (uint8_t)(*huart->pTxBuffPtr++ & (uint8_t)0xFF); huart->Instance->TDR = uhdata; if(uhdata == '\0') huart->TxXferCount = 1; // transmit_running = 1; } huart->TxXferCount--; return HAL_OK; } } else { return HAL_BUSY; } }
Hey Akash Kasturi
Please could you take a look at the forum directory here, https://community.arm.com/developer/f, and let me know where is the best place to move your question to?
Oli from the Community team
Keil forum
