I am using Keil MDK 5.33 and the Segger J-Link Base V6.92. I'm running ST motor code on a STM32G431 MCU. When the motor is not running I can connect the debugger, run my program and inspect watch windows and peripherals. I can also communicate with simple commands over a UART interface. When I start the motor the watch windows stop updating and statically display garbage. I can still communicate over the UART interface while the motor is running. I do have the View->Periodic Update set to update windows but it doesn't occur.
If I then stop the debugger, the motor is still running and I cannot reconnect the debugger. I need to use the UART to stop the motor, then I can reconnect.
Is there a way to be able to have the Keil Watch Windows and debug variables update while the motor is running? Otherwise I am severely hampered in debugging. Is this an issue with the priority level settings? Can the J-link be locked out based on priority seetings?
Thanks for any help you can give,
BT
Original poster adding info:
1. I added a command to my uart code to display a program memory location. Doing this I can examine memory while the motor is running. I can see a variable of interest changing as expected in the uart display but the IDE displays AAAAAAAA for almost all watchpoints and peripheral registers.
2. If I use the IDE command Toolbox--> Window Update it does not for an update. All locations still display AAAAAAAA.
