I am working on STM32G0 micro-controller. In this project, we are using one third party library file(.a file). This library module is allocating one uint32 variable. Once I compile the code with this library, this variable inside the library is not always aligned to 32 bit address. This mis-alignment causes hard fault in my code.
To solve this problem, I defined RAM block of 4 bytes and allocated this block to this file using file->options->zero initialized data.
I just wanted to know if there is some better efficient way of doing it i.e.
1. some options in project settings which can force this uint32 variable to be 4 byte aligned.
2. some options in project settings for the library file (.a file) which can force its variable to 4 byte aligned.
I will prefer not to create separate RAM section for doing it.
