I am new to Cortex M4 programming I am using teensy 3.2 board .I have connected it to PC using USB to TTL cable.I have written a code to transmit a character from Teensy UART to PC .I am using Dockight as terminal. The baudrate is 9600 for a 72MHZ system clock with 8 data bits ,1 start bit,1 stop bit and no parity bit. I have disabled interrupts and DMA Here is my code
#include "MK20D7.h" void UARTPutChar(char); int main() { SIM->SCGC4=1UL<<10; //Clock Enable Uart0 SIM->SCGC5 =1UL<<12;//Enable GPIO PORT D clock UART0->C2=0X00; //Disable UART Tx PORTD->PCR[7]= 0x00000300; //Port pin declare as UART0TX UART0->BDH=0x01; //9600 baudrate 72MHz system clock UART0->BDL=0xEC; UART0->C1=0X00; UART0->C3=0X00; UART0->S2=0X00; UART0->S1=0X00; UART0->C2=0X08; //Enable UART0 Tx while(1) { UARTPutChar('A'); } } void UARTPutChar(char ch) { //if(UART0->S1 == 0X40) //{ UART0->D=ch; //} }
I have configured Docklight settings correctly but i dont receive the character i transmit Here is what i get
Whereas I should receive Ascii of 'A'.I have my self let the Transmit Empty Flag unused for checking. When i used S1 status flag,nothing is transmitted to PC.
