I created a static library for the micro-ecc project using GNU Arm Embedded Toolchain:arm-none-eabi-gcc -Wall -c uECC.cand armar:armar -rcs libuECC.a uECC.o
I added the library file to my Keil Project and I get this error:
Build started: Project: xxx*** Using Compiler 'V5.05 update 1 (build 106)', folder: 'C:\Keil_v5\ARM\ARMCC\Bin'Build Project 'app_main' - Target 'xxx'linking....\release\xxx.axf: Error: L6366E: uECC.o attributes are not compatible with the provided cpu and fpu attributes .Object uECC.o contains Build Attributes that are incompatible with the CPU attributes.Tag_CPU_arch = ARM v4T (=2)Tag_THUMB_ISA_use = Thumb instructions were permitted to be used (=1)Tag_ARM_ISA_use = ARM instructions were permitted to be used (=1).\release\xxx.axf: Error: L6242E: Cannot link object uECC.o as its attributes are incompatible with the image attributes.... wchart-16 clashes with wchart-32.... arm-isa clashes with m-profile.Not enough information to list image symbols.Not enough information to list load addresses in the image map.Finished: 8 information, 0 warning and 2 error messages.".\release\xxx.axf" - 2 Error(s), 0 Warning(s).Target not created.Build Time Elapsed: 00:00:02
If I try to link just the object file on its own (not a static library), I get the same error.
I realize that I'm using an old version of the ARM compiler and upgrading might fix these issues; but I just wanted to know if there is a workaround that I could try first.
" Error: L6366E: uECC.o attributes are not compatible with the provided cpu and fpu attributes" indicates that the build attributes used in your lib built by the gcc compiler are different/incompatible with the ones currently used in your project.
You can use the fromelf.exe together with --decode_build_attributes command line option to decode your lib file as well as your uECC.o to compare the attributes
https://www.keil.com/support/man/docs/armutil/armutil_pge1362128892751.htm
They must be aligned, otherwise you will get this error
So, this is what I get as output from executing
fromelf.exe --decode_build_attributes libuECC.a
** Section #8 '.ARM.attributes' (SHT_ARM_ATTRIBUTES) Size : 48 bytes 'aeabi' file build attributes: 0x000000: 05 41 52 4d 37 54 44 4d 49 00 06 02 08 01 09 01 .ARM7TDMI....... 0x000010: 12 04 14 01 15 01 17 03 18 01 19 01 1a 01 1e 02 ................ Tag_CPU_name = "ARM7TDMI" Tag_CPU_arch = ARM v4T (=2) Tag_ARM_ISA_use = ARM instructions were permitted to be used (=1) Tag_THUMB_ISA_use = Thumb instructions were permitted to be used (=1) Tag_ABI_PCS_wchar_t = Size of wchar_t is 4 (=4) Tag_ABI_FP_denormal = This code was permitted to require IEEE 754 denormal numbers (=1) Tag_ABI_FP_exceptions = This code was permitted to check the IEEE 754 inexact exception (=1) Tag_ABI_FP_number_model = This code may use all the IEEE 754-defined FP encodings (=3) Tag_ABI_align8_needed = Code was permitted to depend on the 8-byte alignment of 8-byte data items (=1) Tag_ABI_align8_preserved = Code was required to preserve 8-byte alignment of 8-byte data objects (=1) Tag_ABI_enum_size = Enum values occupy the smallest container big enough to hold all values (=1) Tag_ABI_optimization_goals = Optimized aggressively for speed, small size and debug illusion sacrificed (=2)
How do I see the attributes of my project and how would I align them?
Surely, the messages are telling you which parts are in conflict:
Anvi said:Build Attributes that are incompatible with the CPU attributes.Tag_CPU_arch = ARM v4T (=2)Tag_THUMB_ISA_use = Thumb instructions were permitted to be used (=1)Tag_ARM_ISA_use = ARM instructions were permitted to be used (=1)
and
Anvi said:attributes are incompatible with the image attributes.... wchart-16 clashes with wchart-32.... arm-isa clashes with m-profile.
For a start, it looks like your project is Cortex-M, but the library is ARM7TDMI ?
I see, thank you for your response. I'm trying to find documentation for the GNU ARM Embedded Toolchain on how to modify these attributes when compiling the library object. I can't seem to find anything explicit
I attempted to re-compile using my target cpu name:
arm-none-eabi-gcc -Wall -O3 -mcpu=cortex-m3 -c uECC.c
error: target CPU does not support ARM mode
Anvi said:and I get this error:
Well, you would: a Cortex-M3 indeed does not support ARM mode - it is Thumb only.
Anvi said:how to modify these attributes when compiling the library object. I can't seem to find anything explicit
Did you read the 'Compilation Notes' in the documentation on the Github page you linked?
Have you tried contacting the author?
I see, I understand. I re-compiled using the following flags:
arm-none-eabi-gcc -Wall -O3 -fshort-wchar -mthumb -mcpu=cortex-m3 -mfix-cortex-m3-ldrd -c uECC.c
I'm able to link the resulting object into my project now. Thanks for you guidance
