Reading battery voltage
Hello Guys,
I am using NucleoF070RB board to read battery voltage using voltage sensor module. I read ADC can be started by three ways Poll Conversion, Interrupts, DMA. I found many examples regarding the Arduino but could not find about STM32 Nucleo boards.
I do not have coding experience. I did the following.
int main(void)
/* USER CODE BEGIN 1 */
uint16_t raw;
char msg[10];
/* USER CODE END 1 */
while (1)
// Test: Set GPIO pin high
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_10, GPIO_PIN_SET);
// Get ADC value
HAL_ADC_Start(&hadc);
HAL_ADC_PollForConversion(&hadc, HAL_MAX_DELAY);
raw= HAL_ADC_GetValue(&hadc);
// Test GPIO pin low
HAL_GPIO_WritePin(GPIOA, GPIO_PIN_10, GPIO_PIN_RESET);
// Convert string and print
sprintf(msg, "%hu\r\n", raw);
HAL_UART_Transmit(&huart2, (uint8_t*)msg, strlen(msg), HAL_MAX_DELAY);
My confusion is now how to intialise the condition for ADC resolution.
Voltage divider Vin= Vout* R2/(R1+R2)  where R1 = 30K, R2 = 7.5K
ADC Resolution= 12 bit ADC = 4096 bits (0 to 4095)
Reference voltage = 3.3V (Microcontroller)
Vout= (Analog read x Reference voltage)/ 4096
I want to write the above formula in the code. But I am confusing how to write it. Can soome one help me
Thanks and Regards
Banala
0
