I try to understand how I can use fopen with the simulator of keil. The processor use is a CORTEX-M4.
I need to do that because I develop unit test under RTRT and use Keil to run the instrumented code. The function fopen is added by RTRT to save the information of the test for the report.
I already read that semihosting is not supported in uVision debugger and I need to redefine the _sys functions but I can't find any example that create file.
Is someone as already had this problem?
Best regards
Alexandre
