I need to flash a .hex file to my board. I followed the steps in this guide to achieve that but I'm getting:
Error: Flash Download failed - Could not load file 'C:\Projects\MyBoard\MyFirmware.axf'
I don't have a MyFirmware.axf file, I have a MyFirmware.hex file that is what I need to flash. I put that .hex file in the "Objects" folder and configured uVision to point to that folder to grab the .hex file.
Does anyone know how to work with only hex files? Because the documentation solution doesn't work.
Note: I'm not compiling the code in uVision, I just need to use it to flash an already existing .hex file.
"3 Enter the HEX file name into the field Project — Options for Target — Output — Name of Executable."
Make sure you have the file name with .hex extension on the target
i.e. The name of the executable should be.
FileName.hex. If you don't put the .hex on the end it will assume it is an axf file.
