Sorry if this is a really stupid question but I'm trying to move from STM32CubeIDE to Keil uVision. As is probably fairly obvious I'm not very experienced with C.
When I import a library that requires the "_ansi.h" the library can't be found and indeed searching for it on the local file system shows that it's not present in any of the project's include folders.
I know I can go download it from somewhere (or just copy from my existing STM32CubeIDE folders) but given that, so far as I can tell, this is a fairly standard requirement I wanted to check that I'm not missing something obvious, particularly as I can find no reference to this problem on the forums.
Do I have to install this dependency manually? I'd have thought there was some sort of pack with the standard GNU libraries or some such?
I recommend to start from here:
"Using Keil MDK with STM32CubeIDE"
https://www.keil.com/appnotes/files/apnt_323.pdf
Also - as a starter - take a look at:
"Getting started with MDK"
https://www.keil.com//support/man/docs/mdk_gs/gs_MDK5_5_en.pdf
The latest MDK-release can be downloaded at:
http://www2.keil.com/mdk5
