I want to move from Keil Compiler 5.6 to 6.13 for my FreeRTOS based code on Cortex M4. I found out the following problems in doing so,
1) cmsis_armclang.h was not found. For this I found a compatible version from web and used that, it works but not sure if it is a good idea.
2) FreeRTOS/portable/RVDS/Cortex_M4F/portmacro.h and port.c has problems with __asm call. To solve this, I started using FreeRTOS/portable/GCC/Cortex_M4F/portmacro.h and port.c. Again this works but, not sure if it is a good idea.
3) There are some keil specific libraries like, Segger's RTT_Syscalls_Keil which does not work anymore. Can I use the GCC one here too?
Please comment on my solutions and problems. If there are better ways or something that I miss, please let me know.
I have an active project using CMSIS RTOS2 based on FreeRTOS and ARMCLANG v6.14. Digging into the header files:
I don't use Segger tools, so I can't answer that part of your question.
For 3rd-party stuff (FreeROS, Segger) it's probably best to go to the 3rd-part and ask if they have updates for the new compiler ...
