I want to control the ad9833 module with the stm32f4 development board. I have a library but I couldn't get SPI communication. I cannot get any wave output from the module. I cannot adjust frequency. where can the problem be? I need to create this project with CUBEMX and do the work using the Keil development environment. I am using the SPI1 module of the board. I use PA5 pin as SCK, PA7 pin as MOSI and PB2 pin as GPIO reset. Below is the code part that i tried to spi communication.
void ad9833_send(uint16_t dat) { unsigned char i; HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_SET); //clk = 1 for(i=0; i<16; i++) { if (dat & 0x8000) { HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_SET); } else { HAL_GPIO_WritePin(GPIOA, GPIO_PIN_7, GPIO_PIN_RESET); } HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET); dat <<= 1; __NOP(); __NOP(); HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET); } //HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET); }
BYHLM said:I am using the SPI1 module of the board
It really doesn't look like you do. If you were actually using SPI, your calls to the HAL wouldn't all have "GPIO" in them.
BYHLM said:ad9833
You mean this: https://www.analog.com/en/products/ad9833.html ?
BYHLM said:I couldn't get SPI communication
Clearly, that is absolutely fundamental: the AD9833 is an SPI device - so you won't be able to do anything before you've got SPI working.
Getting the STM32 SPI to work is nothing to do with Keil or ARM - you need to study the ST datasheet, User Manual, Application Notes, Examples, etc for that.
https://www.st.com/en/microcontrollers-microprocessors/stm32f4-series.html
Lots of training resources available from ST:
community.arm.com/.../109675
For support with ST specifics, you need to go to ST:
https://community.st.com/s/
See:
community.arm.com/.../158950
