I Good evening Everyone.
I am beginner for Programming of LPC2148.
I am making a project on transmitting temperature and location on my mobile by Bluetooth HC-05.
So I am using UART0 and ADC 0.6 such that Received data from GPS (NEO -6M) and ADC (LM35) will be transmitted to HC-05
Below is the program, I have written I am getting GPS data but no output from ADC0.6.
#include<lpc214x.h>void pll0(void);void uart0(void);char adc0_lm35(void);char gps_data(void);void message(char *ch);void tx(unsigned char a);void delay(int b);
int main(){ PINSEL0 = 0x00000305; char gps; char adc; while(1) { pll0(); uart0(); gps = gps_data(); adc = adc0_lm35(); message(&gps); message(&adc); }} void pll0(void) //setting PLL0 to generate 60Mhz Peripheral clock for UART0,UART1 and ADC0;{ PLL0CON = 0x01; //Enable PLL0 PLL0CFG = 0x24; //Configure PLL0 as P=2 and M=5 to generate PCLK = 60Mhz PLL0FEED = 0xAA; //PLLFEED sequence PLL0FEED = 0x55; //PLLFEED sequence if((PLL1STAT&0x0400)==0); //wait till PLL locks at 60Mhz PLL0CON = 0x03; //Enable and connect PLL PLL0FEED = 0xAA; //PLLFEED sequence PLL0FEED = 0x55; //PLLFEED sequence VPBDIV = 0x01; //VPB bus clock is same as processor clock}
void uart0(void) //setting baud rate to 9600 for gps in UART0{ U0LCR = 0x83; //world length 8bit, single stop bit, disable parity generator, odd parity, disable break transmittion, Enable Divisor latches U0DLL = 110; // load U0DLL = 110 U0DLM = 1; // load U0DLM = 1 U0FDR = (15<<4) | 1; //MULVAL = 15; Enable Divisor latches U0LCR &= 0x0F; // Disable Divisor latches }
char gps_data(void){ while((U0LSR & 0x01) == 0); return (U0RBR);}
void message(char *ch){ while(*ch!='\0') { tx(*ch); ch++; }}
void tx(unsigned char a){ while((U0LSR & 0x20) == 0); U0THR = a;}
void delay(int b){ T0CTCR = 0x00; T0PR = 12000000; T0TCR = 0x02; T0TCR = 0x01; while(T0TC<b); T0TCR = 0x00;}
char adc0_lm35(void){ char adc; while(1) { AD0CR=0x01201440; while(!(AD0GDR&0x80000000)); // Wait for the done bit to finish (using the general register) adc = ((AD0GDR>>6)&0x3FF); return (adc); }}
Rohit Jadhav said:I am beginner for Programming of LPC2148
Why start with such an old part?
See: community.arm.com/.../158931
And note that this has nothing to do with Keil or ARM - it's NXP you need to be asking about the specific operation of their chips:
https://community.arm.com/developer/tools-software/tools/f/keil-forum/43684/lpc2148-timer0-not-working-as-expected/158950#158950
https://community.nxp.com/
Do you have any experience with any other microcontroller(s) ?
Bluetooth communication is not a beginner's project!
For getting started with any microcontroller, see:
https://www.avrfreaks.net/comment/1138166#comment-1138166
thanks for your valuable input.
yes, I have made the project of led blink with button and timer on lpc2148. I have also made a project with turning on and off led with hc-05
https://www.youtube.com/watch?v=KkIPm2cjN-g
I am surely going to upgrade my self with the latest controllers but I am clearing my basics with lpc2148.
