I have the X Y Z coordinates data from the accelerometer which is taken at different frequencies and is in the time domain. I have to convert those values to the frequency domain. I know I have to use FFT but how do I implement that in C. Is there any example code for it?? {-237,-248,195,174,-23,-89,-224,...} Above is the sample X coordinate data which is in the time domain at 50Hz. How to find the FFT of this??
Go on - there's loads of stuff on the interwebs about doing FFTs in 'C' !
https://www.dspguide.com/pdfbook.htm
http://www.lmgtfy.com?q=fft+c
Since you're specifically on the Keil forum, the CMSIS DSP library would be the obvious place to start:
https://www.keil.com/pack/doc/CMSIS/DSP/html/index.html
https://www.keil.com/pack/doc/CMSIS/DSP/html/group__groupTransforms.html
There is a FFT example in the Pack Installer.You can take reference from it.
