I'm trying to debug a continuous ADC signal. Unfortunately every few µs the Trace buffer overflows. This results in Steps inside the Logic analyzer. Is there a way to set it to a bigger size?
I'm using Keil with a STM32H7 Nucleo board with the ST-Link v2 debugger.
ThanksRegards Fanta
Example:
Which debug adapter are you using ?
If it is ULINK2 then below link should be helpful:http://www.keil.com/support/man/docs/ulink2/ulink2_trace_status.htm
If it is ULINK Pro then below link should help:http://www.keil.com/support/man/docs/ulinkpro/ulinkpro_trace_status.htm
Says ST-LINK/V2
