I install Canvas & model debugger evaluation on win7 which run.
I create a project & compiler on Canvas Model Build process completed successfully!!
then I use "Debug" on Canvas.
The model debugger show "Error (Cannot load model library) Cannot load model library 'D:\Program Files\ARM\FastModelsPortfolio_11.8\examples\Tool-Solutions-master\Tool-Solutions-master\hello-world_fast-models\Cortex-A_Armv8-A\system\Win64-Release-VC2015\cadi_system_Win64-Release-VC2015.dll': Error: General error: ERROR: License checkout for feature SG_ARM_Cortex-A53_CT with version 11.8 has been denied by Flex back-end. Error code: -5 No such feature exists. Feature: SG_ARM_Cortex-A53_CT License path: D:/license.dat;c:\program files\arm\licenses\license.dat; FlexNet Licensing error:-5,357 Error: No License found: <Ok>"
how can i fix it? thanks
This doesn't seem to be anything to do with Keil ?
This is a licensing error. The most likely causes are either (a) you haven't got a valid license to run the Cortex-A53 Fast Model, or (b) the LM_LICENSE_FILE and ARMLMD_LICENSE_FILE environment variables are set up incorrectly. Please do the following and let me know the results.
