I would like to use ARMClang 6 series toolchain (compiler and linker) to build and compile or debug for STM32F103RB board Evaluation board.I want to use CLion instead of Keil IDE for compiling/flashing and debugging the EVAL board.Currently CLion has a plugin that supports for arm-gcc but nothing for ARMClang yet.Since the build backbone of the CLion is CMake which is a way different from Keil build system all my efforts to create a successful build system in Cmake has failed.I want to replicate following flags in CMake (Both for Release and Debug) setting if possible with .hex file as an output too
Compiler Flags> -xc -std=c99 --target=arm-arm-none-eabi -mcpu=cortex-m3 -c -fno-rtti -flto -funsigned-char -fshort-enums -fshort-wchar -gdwarf-3 -Ofast -ffunction-sections -Wno-packed -Wno-missing-variable-declarations -Wno-missing-prototypes -Wno-missing-noreturn -Wno-sign-conversion -Wno-nonportable-include-path -Wno-reserved-id-macro -Wno-unused-macros -Wno-documentation-unknown-command -Wno-documentation -Wno-license-management -Wno-parentheses-equality -I ../../Core/Inc -I C:/Users/TS/STM32Cube/Repository/STM32Cube_FW_F1_V1.8.0/Drivers/STM32F1xx_HAL_Driver/Inc -I C:/Users/TS/STM32Cube/Repository/STM32Cube_FW_F1_V1.8.0/Drivers/STM32F1xx_HAL_Driver/Inc/Legacy -I C:/Users/TS/STM32Cube/Repository/STM32Cube_FW_F1_V1.8.0/Drivers/CMSIS/Device/ST/STM32F1xx/Include -I C:/Users/TS/STM32Cube/Repository/STM32Cube_FW_F1_V1.8.0/Drivers/CMSIS/Include -I./RTE/_stm32f103rbt6-LCD-CubeMX -IC:/Users/TS/AppData/Local/Arm/Packs/ARM/CMSIS/5.5.1/CMSIS/Core/Include -IC:/Users/TS/AppData/Local/Arm/Packs/Keil/STM32F1xx_DFP/2.3.0/Device/Include -D__UVISION_VERSION="528" -D_RTE_ -DSTM32F10X_MD -DUSE_HAL_DRIVER -DSTM32F103xB -o stm32f103rbt6-LCD-CubeMX/*.o -MD
ASM> armasm --cpu Cortex-M3 -g -I.\RTE\_stm32f103rbt6-LCD-CubeMX -IC:\Users\TS\AppData\Local\Arm\Packs\ARM\CMSIS\5.5.1\CMSIS\Core\Include -IC:\Users\TS\AppData\Local\Arm\Packs\Keil\STM32F1xx_DFP\2.3.0\Device\Include --pd "__UVISION_VERSION SETA 528" --pd "_RTE_ SETA 1" --pd "STM32F10X_MD SETA 1" --list *.lst --xref -o stm32f103rbt6-LCD-CubeMX\*.o --depend stm32f103rbt6-LCD-CubeMX\*.d
Linker armlink> --cpu Cortex-M3 --lto *.o --strict --scatter "stm32f103rbt6-LCD-CubeMX\stm32f103rbt6-LCD-CubeMX.sct" --summary_stderr --info summarysizes --map --load_addr_map_info --xref --callgraph --symbols --info sizes --info totals --info unused --info veneers --list "stm32f103rbt6-LCD-CubeMX.map" -o stm32f103rbt6-LCD-CubeMX\stm32f103rbt6-LCD-CubeMX.axf
Any help with creating CMakeLists.txt file is really appreciated.
siso said:I want to use CLion instead of Keil IDE
So why are you posting in the Keil forum?!
The Keil forum is for questions about the Keil tools - for questions about CLion (or whatever else), you need to find a CLion forum!
EDIT
You might look at some of the posts about migrating to Eclipse - they should give you some tips on how to extract / replicate settings from Keil projects...
eg,
https://community.arm.com/developer/tools-software/tools/f/keil-forum/44670/how-to-convert-keil-project-uvprojx-to-eclipse
Geez, what an un-helpful reply. "Keil" includes a huge amount of middleware in addition to a crappy IDE. I'm sure lots of us need to use the middleware, but want a decent IDE.
