haii all...i have a problem with my keil stm32f103c8t6 code with sim800l...
i m sending energy data to website using sim800l with keil ide.. the problem is i m able connect with internet but i m not be able send any data till now.. i have attached keil code please give me suggetion where i m doing wrong...
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "stm32f1xx_hal.h"
#include "string.h"
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
ADC_HandleTypeDef hadc1;
UART_HandleTypeDef huart1;
UART_HandleTypeDef huart3;
DMA_HandleTypeDef hdma_usart1_rx;
DMA_HandleTypeDef hdma_usart1_tx;
DMA_HandleTypeDef hdma_usart3_rx;
DMA_HandleTypeDef hdma_usart3_tx;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_DMA_Init(void);
static void MX_ADC1_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_USART3_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_DMA_Init();
  MX_ADC1_Init();
  MX_USART1_UART_Init();
  MX_USART3_UART_Init();
  /* USER CODE BEGIN 2 */
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
	//*************************************AT commands to connect internet*********************************************
  while(1){
char getstr[200]="id=";
uint8_t myPrintData_0[10]="Start\r\n";
uint8_t myPrintData_1[20]="Sending Data...\r\n";
uint8_t myclockData_1[15]="AT+CCLK?\r\n";
uint8_t myTxData_0[50]="AT\r\n";
uint8_t myTxData_1[50]="AT+SAPBR=3,1,\"Contype\",\"GPRS\"\r\n";
uint8_t myTxData_2[50]="AT+SAPBR=3,1,\"APN\",\"\"\r\n";
uint8_t myPrintData_2[30]="Connecting to internet...";
uint8_t myTxData_4[50]="AT+SAPBR=1,1\r\n";
uint8_t myPrintData_3[40]="Internet Connection Established";
uint8_t myTxData_5[50]="AT+HTTPINIT\r\n";
uint8_t myTxData_11[200]="AT+HTTPPARA=\"URL\",\"http://credencerobotics.000webhostapp.com/value.php?id=SP0007&v=823.00&i=209.00&kw=440.00&kwh=65.00&kva=92.00&kvar=242.00&pf=87.00&f=203.00";
uint8_t data_1[50]="\"";
uint8_t myTxData_8[20]="AT+HTTPACTION=0";
uint8_t myTxData_9[20]="AT+HTTPREAD";
uint8_t myTxData_10[20]="AT+HTTPTERM";
	HAL_UART_Transmit(&huart3,myclockData_1,20,10); //print clock data
	HAL_Delay(1000);
	HAL_UART_Transmit(&huart1, myPrintData_0,10,10); //print start
	HAL_Delay(1000);
	HAL_UART_Transmit(&huart3,myTxData_0,50,20);
	HAL_Delay(2000);
	HAL_UART_Transmit(&huart3,myTxData_1,50,20);
	HAL_Delay(2000);
	HAL_UART_Transmit(&huart3, myTxData_2,50,20);
	HAL_Delay(2000);
	HAL_UART_Transmit(&huart1, myPrintData_2,30,20);
	HAL_Delay(2000);
	HAL_UART_Transmit(&huart3, myTxData_4,50,20);
    HAL_Delay(2000);
	HAL_UART_Transmit(&huart3, myPrintData_3,40,30);
    HAL_Delay(3000);
    HAL_UART_Transmit(&huart3, myTxData_5,50,30);
    HAL_Delay(3000);
	HAL_UART_Transmit(&huart3, myTxData_11,200,10);
	HAL_Delay(5000);
	HAL_UART_Transmit(&huart3, data_1,5,10);
	HAL_Delay(5000);
	HAL_UART_Transmit(&huart3, myTxData_8,20,10);
    HAL_Delay(5000);
    HAL_UART_Transmit(&huart3, myTxData_9,20,10);
	HAL_Delay(5000);
    HAL_UART_Transmit(&huart3, myTxData_10,20,10);
	HAL_Delay(5000);
  /* USER CODE END 3 */
/** System Clock Configuration
  RCC_OscInitTypeDef RCC_OscInitStruct;
  RCC_ClkInitTypeDef RCC_ClkInitStruct;
  RCC_PeriphCLKInitTypeDef PeriphClkInit;
    /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
  RCC_OscInitStruct.HSIState = RCC_HSI_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    _Error_Handler(__FILE__, __LINE__);
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
  PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_ADC;
  PeriphClkInit.AdcClockSelection = RCC_ADCPCLK2_DIV6;
  if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
    /**Configure the Systick interrupt time
  HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  /* SysTick_IRQn interrupt configuration */
  HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
/* ADC1 init function */
  ADC_ChannelConfTypeDef sConfig;
    /**Common config
  hadc1.Instance = ADC1;
  hadc1.Init.ScanConvMode = ADC_SCAN_DISABLE;
  hadc1.Init.ContinuousConvMode = DISABLE;
  hadc1.Init.DiscontinuousConvMode = DISABLE;
  hadc1.Init.ExternalTrigConv = ADC_SOFTWARE_START;
  hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT;
  hadc1.Init.NbrOfConversion = 1;
  if (HAL_ADC_Init(&hadc1) != HAL_OK)
    /**Configure Regular Channel
  sConfig.Channel = ADC_CHANNEL_1;
  sConfig.Rank = 1;
  sConfig.SamplingTime = ADC_SAMPLETIME_1CYCLE_5;
  if (HAL_ADC_ConfigChannel(&hadc1, &sConfig) != HAL_OK)
/* USART1 init function */
  huart1.Instance = USART1;
  huart1.Init.BaudRate = 115200;
  huart1.Init.WordLength = UART_WORDLENGTH_8B;
  huart1.Init.StopBits = UART_STOPBITS_1;
  huart1.Init.Parity = UART_PARITY_NONE;
  huart1.Init.Mode = UART_MODE_TX_RX;
  huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart1.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart1) != HAL_OK)
/* USART3 init function */
  huart3.Instance = USART3;
  huart3.Init.BaudRate = 115200;
  huart3.Init.WordLength = UART_WORDLENGTH_8B;
  huart3.Init.StopBits = UART_STOPBITS_1;
  huart3.Init.Parity = UART_PARITY_NONE;
  huart3.Init.Mode = UART_MODE_TX_RX;
  huart3.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart3.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart3) != HAL_OK)
