i am using KEIL in my project. i am using STM32F030 as transmitter and STM32F4 as a receiver. When i run my code in debug mode both of them work properly. But when i press terminate and re-insert my ST-LINK device i can't see any data in my receiver (also i see that receiver and transmitter connects). How can i download the code and use it without debug mode? I see that similar questions are there already. But they did'nt work for me. In main.c there are only CubeMX configurations. So i share only my dht22.c file
main.c
dht22.c
Here is my code:
/* #include "main.h" //buraya don #include "stm32f0xx_hal.h" #include "dht22.h" uint8_t nem_byte1, nem_byte2, sicaklik_byte1, sicaklik_byte2,checksum, verilerin_toplami; uint16_t nem, sicaklik,sicaklik1,nem1,timer_sayac_degeri; void delay_ticks(uint32_t ticks) { //SYSTICK TIMER 24 BIT SysTick->LOAD = ticks; //girilen süre için gerekli tick sayısı SysTick->VAL = 0; SysTick->CTRL = SysTick_CTRL_ENABLE_Msk; SysTick->CTRL &= ~SYSTICK_CLKSOURCE_HCLK_DIV8; SysTick->CTRL |= SYSTICK_CLKSOURCE_HCLK; //COUNTFLAG,counter 0 oldugunda 1 oluyo. //okundugunda otomatik oalrak temizleniyo while ((SysTick->CTRL & SysTick_CTRL_COUNTFLAG_Msk) == 0); SysTick->CTRL = 0; } void delay_us(uint32_t us) { delay_ticks(us * 8); } static inline void delay_ms(uint32_t ms) { delay_ticks(ms * 8000); } GPIO_InitTypeDef GPIO_InitStruct = {0}; void pini_giris_yap (void) { GPIO_InitStruct.Pin = GPIO_PIN_5; GPIO_InitStruct.Mode = GPIO_MODE_INPUT; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); } /*Configure GPIO pin : PA2 */ void pini_cikis_yap (void) { GPIO_InitStruct.Pin = GPIO_PIN_5; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); } void DHT22_baslat (void) { pini_cikis_yap(); HAL_GPIO_WritePin (GPIOA, GPIO_PIN_5, 0); // baslangica sinyali delay_us(1100); HAL_GPIO_WritePin (GPIOA, GPIO_PIN_5, 1); // sensorden gelecek cevabi bekle delay_us(30); pini_giris_yap(); } void sensorden_yanit_al (void) { delay_us(120); //datasheete gore 80-160 arasi bir deger while ((HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_5))); } uint8_t veri_oku(void) { uint8_t i,j; for (j=0;j<8;j++) { while (!(HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_5))); // pin 1 olana keder bekle delay_us(40); // 50 yapinca calismiyo if ((HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_5)) == 0) { i&= ~(1<<(7-j)); // alinan bit 0 } else i|= (1<<(7-j)); // alinan bit 1 while (HAL_GPIO_ReadPin (GPIOA, GPIO_PIN_5 && ((TIM3->CNT-timer_sayac_degeri)==1600) )); //problem olursa 200 us sonra devam et } return i; } void oku(void){ DHT22_baslat (); sensorden_yanit_al (); nem_byte1 = veri_oku(); nem_byte2 = veri_oku(); sicaklik_byte1 = veri_oku(); sicaklik_byte2 = veri_oku(); checksum = veri_oku();// check-sum should be the last 8 bit of "8 bit integral RH data+8 bit decimal RH //data+8 bit integral T data+8 bit decimal T data". verilerin_toplami=(nem_byte1+nem_byte2+sicaklik_byte1+sicaklik_byte2); // HAL_UART_Transmit(&huart1,(uint8_t*)"resul\r\n",sizeof("resul\r\n")-1,100); if ((checksum) == verilerin_toplami) { sicaklik = ((sicaklik_byte1<<8)|sicaklik_byte2); nem = ((nem_byte1<<8)|nem_byte2); } }
